Adding a 2nd fan?
Old Jun 22, 2021 | 11:57 AM
Catch_KC's Avatar
Catch_KC
Originally Posted by Moparite
I have the adjustable controller and it lasted for years but last year the positive terminal melted so i have to get another one. It also can wired for a switch in the cab to turn it on.
So you had an adjustable switch in the cab with you? I'd like to tap into the AC signal so the fan automatically comes on when the AC is running?
Old Jun 22, 2021 | 05:55 PM
Spillage's Avatar
Spillage
Originally Posted by Catch_KC
… I'd like to tap into the AC signal so the fan automatically comes on when the AC is running?
I tapped into the compressor clutch wire.
Old Jun 22, 2021 | 07:00 PM
I would guess you just used that to control a relay?
Old Jun 23, 2021 | 06:50 AM
Moparite's Avatar
Moparite
This controller will do just that, The PCM controls the relay so it's not on all the time. You need to tap into the switch in the dash control.
https://www.flex-a-lite.com/accessor...ol-module.html
Old Jun 23, 2021 | 07:04 AM
Spillage's Avatar
Spillage
It’s just a sense wire for the fan controller, so it knows the A/C is ‘on’.
