Is it possible to use 2001 durango transmission/front end to convert a 2wd ram1500
Old Aug 5, 2021 | 10:50 PM
duckdodgerz's Avatar
duckdodgerz
Default Is it possible to use 2001 durango transmission/front end to convert a 2wd ram1500
I just bought a 2001 2wd ram 1500(5.2L) with a bad transmission, but only 84k miles, no rust, came from Texas. I have a 2001 durango 4.7L 4x4 that is parked but still runs well. Can I interchange the transmission, xfer case between the two?
Old Aug 5, 2021 | 10:57 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yep
Old Aug 5, 2021 | 11:08 PM
duckdodgerz
Sweet. I presume the axles will be different, i'm expecting them to be longer for the ram. Are there any other parts that might be interchangeable?
Old Aug 5, 2021 | 11:56 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would say no, Because the 4.7 has a 545RFE transmission and the 5.2 may have either the 44 or 46RE transmission.
Old Aug 6, 2021 | 02:39 AM
MoparFanatic21
I misread that. You would be correct. It will bolt up but won't run need a different TCM
Old Aug 6, 2021 | 06:56 AM
A 4x4 trans isn't gonna work in a 2wd truck either.....
Old Aug 6, 2021 | 08:40 AM
duckdodgerz
Yeah, I was looking to see if I could do a 2wd to 4wd conversion.
Old Aug 6, 2021 | 08:44 AM
duckdodgerz
I'll have to find out what tranny is in it and go from there. It goes in reverse just fine, and it'll shift and go in forward gears for a couple minutes, then it only reverse works. I'll do some reading to see if I have other options. Not opposed to buying a reman tran, just looking for other options.
I have another questions, A local guy has a 5 speed out of a 2004-5 ram with a 5.2L. Is it possible to use it with some linkeage changes?
Old Aug 6, 2021 | 10:16 AM
MoparFanatic21
Never made a 5 2L in 04-05 probably a g56 behind a Hemi and yes it will work. Also converting to 4wd isn't worth it and will take a lot of time
Old Aug 6, 2021 | 10:30 AM
duckdodgerz
Thanks for the info. I'll ditch the 4wd swap idea.
I did confirm that I have a 46RE. Besides putting the A5 5 speed transmission in, what else would I need to do?
