What did i do wrong
Old Sep 4, 2021 | 04:45 PM
ajp89's Avatar
ajp89
Default What did i do wrong
Tranny (46RE) went in my 2001 2500 360. While having the tranny out, I did a little maintenance while I had the room: rear main seal, oil pan gasket, clean oil pan/oil pump, transfer case seals, ball valve delete, along with a rebuilt transmission.
After reinstalling, on initial startup, I blew out the seal on my engine oil filter. I was hoping maybe I didn’t have it on tonight enough or it was a defective filter but it’s not. I bought another and the same thing happened. I took a video of the filter on the second startup and as it builds oil pressure, you can actually see the bottom of the filter bubble out and then the seal gives loose and pukes oil everywhere. Yes, I instantly shut it off each time.
Did I do something wrong??? Could it be the PCV valve not letting enough pressure out? Should I have replaced the oil pump? I didn’t have oil pressure issues before so I’m assuming it’s something I did. Any help is appreciated!
Old Sep 4, 2021 | 04:53 PM
ajp89's Avatar
ajp89
Tried uploading the video and can’t get it to work
Old Sep 5, 2021 | 06:53 AM
Moparite's Avatar
Moparite
What did the oil pressure go up to on the gauge? You either have a blockage or a defective pump. In the pump there is a relief valve so the pressure doesn't go to high that's why i asked.
Old Sep 5, 2021 | 07:08 AM
ajp89's Avatar
ajp89
not exactly sure. I saw the needle keep rising then I shut it off as soon as I heard the oil coming out.
Old Sep 5, 2021 | 07:19 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Need to post the video on YouTube then post the link here. Did you install the oil pump right?
Old Sep 5, 2021 | 10:45 AM
ajp89's Avatar
ajp89
doesn’t it only go on one way? It wouldn’t bolt on or even fit in the pan any other way?
Old Sep 5, 2021 | 10:48 AM
I have seen this particular issue before on a Honda. The oil pressure relief valve jammed, so the engine was getting pump pressure. (north of 1000PSI) Of course, the filter isn't rated for that kind of pressure, and it would go spherical, and then blow out the crimp seam, and oil went everywhere. Replace the oil pump, (which the relief valve is part of,) and the problem was gone.
Old Sep 5, 2021 | 10:59 AM
ajp89's Avatar
ajp89
it’s sounding like this is the issue. I’ve heard a few people mention this exact thing while doing some online research. I’m guessing after I cleaned the pump/pickup tube in a parts cleaner, I let it sit too long before oiling up and installing it. Maybe it got stuck inside after being dry too long.
Old Sep 5, 2021 | 11:13 AM
master tech's Avatar
master tech
Site Moderator & Tech
Could be a stuck pressure release valve or maybe the bottom half of the dist shaft that does into the pump isn't connected?
