Charging problems 1996 Ram 3500 diesel
Old Sep 23, 2021 | 07:44 AM
2Ram3500s's Avatar
2Ram3500s
Default Charging problems 1996 Ram 3500 diesel
I have a 1996 Ram 3500 diesel and was having shift problems. After checking the transmission wiring with a test light for power the alternator stopped charging and the wait to start/water in fuel / trans temp lights stopped working. Also now I have no power at the transmission. I've checked all connections, relays and the alternator. I'm thinking PCM problems but the closest tester is 30 miles away. Any ideas or information?
Old Sep 23, 2021 | 08:21 AM
Should only see power at the trans for a few seconds, unless the engine is running.
Old Sep 23, 2021 | 03:17 PM
2Ram3500s's Avatar
2Ram3500s
What about the loss of charging and the lights?
Old Sep 23, 2021 | 03:32 PM
Might be an entirely separate issue. Or, it might be related. Did you pop a fuse??
Old Sep 23, 2021 | 03:39 PM
2Ram3500s's Avatar
2Ram3500s
No all fuses and relays are good.
Old Sep 23, 2021 | 07:10 PM
So, verify you are getting power to the injectors, and coil, at initial key on.
Old Sep 24, 2021 | 08:12 AM
2Ram3500s's Avatar
2Ram3500s
This vehicle is a 1996 12 valve diesel. Manual injectors and no coil.
Old Sep 24, 2021 | 09:57 AM
Grab the factory service manual for your truck from here. Wiring diagrams are in section 8W. If you have a scanner that can read live data, see if it will even talk to the PCM.
Old Sep 26, 2021 | 06:23 AM
2Ram3500s's Avatar
2Ram3500s
Thank you for the information and the link. It will be very useful in the future. The problem was the PCM. I installed a refurbished unit and all problems solved.
Old Sep 26, 2021 | 10:24 AM
Awesome.
