Link To Make Your Night Driving Brighter!
Old Jan 2, 2006 | 03:49 AM
  #21
ebxgsxr's Avatar
ebxgsxr
Default RE: Link To Make Your Night Driving Brighter!
ORIGINAL: Ram_Sport
why would it be illegal? i drive w/ fogs&lowbeam all the time and high when i want to see everything once in awhile
yeah but your fogs should turn off unless you have done the modification. im going to try it @ my shop tomorrow.
Old Jan 2, 2006 | 06:23 PM
  #22
bamory's Avatar
bamory
I did it to mine using an auxillary 12V light switch with 2 prongs, plugged right into #3 and #5, very clean and then i just flipped the switch.
Old Jan 3, 2006 | 04:33 AM
  #23
Racinfan83's Avatar
Racinfan83
ORIGINAL: bamory
Nice, I'll have to look into that.....
Old Jan 6, 2006 | 06:54 PM
  #24
Racinfan83's Avatar
Racinfan83
Got out and did mine today, used a jumper wire cause I didn't have a switch handy. Works great. Gonna look into doing this on the 300C now also.
Old Jan 7, 2006 | 07:03 PM
  #25
mossy765's Avatar
mossy765
i have a 1999 ram 2500 and ive been wanting to to do that hi/low beam headlight and that website confused me on how to do it so i was wondering if anyone else had a easier way to do it
Old Jan 7, 2006 | 09:41 PM
  #26
ebxgsxr's Avatar
ebxgsxr
just wondering...what gauge wire are you guys using when using the jumper wire?
Old Jan 7, 2006 | 09:44 PM
  #27
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
ORIGINAL: Racinfan83
Could you do a How To on this to publish on this site? Pretty please?
~Amanda
Old Jan 8, 2006 | 02:14 AM
  #28
Racinfan83's Avatar
Racinfan83
ORIGINAL: Dodgegirl19
~Amanda
Amanda, I'm not sure what you mean by a "How To"? In case you missed it, there is a link in my first post that brings up detailed instructions and a pic. I used a piece of normal size automotive wire about 1 1/2 inches long, stripped both ends and crimped on electrical spade lugs. You then find the "fog light relay" in the power distribution center (the black box behind your battery) and pull it out. There is a map of all the relays on the inside of the PDC lid. The fog light relay has 5 spades 3 that run sideways to the truck, and 2 that run parallel to the length of the truck. On mine these two were the closest to me. All you do is plug one spade on the jumper into one of the parallel terminals and the other end of the jumper to the other parallel terminal. They will end up plugged in next to each other. Picture and diagram is in the above link. Throw the relay in the glove compartment in case you ever need it.
If this isn't what you need, repost or pm me. Like I said, I'm going to look and see if this is possible on our 300C also when I get a chance. I haven't done the other light mod in the thread that makes both low and high beams work at the same time - so all I know about is the foglight mod.
Old Jan 9, 2006 | 12:23 AM
  #29
ebxgsxr's Avatar
ebxgsxr
great write up. very easy to do, and definitely makes a nice difference at night. i did it today @ work. i think the longest part of the while thing was crimping the spade connectors to the wire
Old Jan 9, 2006 | 12:47 AM
  #30
Tani1500's Avatar
Tani1500
i just did it. worked great!!!!!!
