OBD1 MOPAR Performance PCM
Hello all
I am really wanting to switch to a performance PCM since I m about to do a cam swap and upgrade the plenum.
I have been having one hell of a time trying to find one if anybody can help me find one or know of a place to get a used one that will not cost me an arm and a leg that would be great.
THank you all for your time with this.
Changing over wouldn't really be that hard either. Trouble comes from the trans. If it's a manual trans, then no issue, and automatic though..... is a whole 'nother kettle o' fish. Although, there is at least one member here with a 96 truck, which should be OBDII, with an RH trans......
Hello
so yes California still required to get smog done every two years with this truck but as long as I have no lights on and it will pass the sniffer test I should be ok.
I would love to go stand alone but I have no clue how to tune and the few shops I have called only do obd2 stuff so I am SOL.
I was hoping to see if you all put out your feelers to see if anybody has the performance PCM for my truck. I found two on eBay but they want 600+ for them and they are used and I don’t to have it for a week and then it go out and I am screwed. But don’t mind spending some money on it to get the PCM I need and want.
thank you all
thank you all
Ya I am finding out that these PCM's are liking finding gold.
if anybody sees one or even hears of one can they shoot me a message I really want one.
With all this being said how are would it be to get my PCM reflashed from someone I have tried the two different people that I have seen on the forums but they seem not to want to get back to me.
Or should I just give up and just try for a really good stock build or do a Hemi swap?
Trending Topics
In my honest opinion there’s much you can do to boost your engine without a tune/pcm
fixing plenum, headers/exhaust, ignition, re gear axles, cam, 1.7 rockers pushrods, have heads check/ get new ones as stocks are known to crack when added power is put in….there’s a few grand to get you started
or just go all out….408 stroker
Might want to speak with folks at BG Performance, as they used to work with OBD1 PCMs a while ago - http://www.bgperformance.com/
You can also check with these folks for possible OBD1 options - http://utawesomeperformance.com/index.html
Just a warning, sticking with the OBD1 platform will likely be more costly, no matter which way you go.
