Rear Brake ABS
Old Oct 31, 2021 | 03:23 PM
BClark_35's Avatar
BClark_35
Why do you want an adjustable proportioning valve?? So far as I know, that valve is the same for both disk, and drum brakes. ABS takes care of any serious imbalance.
Well i don't want one. I'm just asking in case there is a difference that shows itself later on. Like brake pad wear or something like that. Guess I'm just curious at this point
Old Oct 31, 2021 | 03:29 PM
In my opinion, for whatever that's worth, You don't need one. It's my understand that there really aren't any difference in master cylinder, proportioning valve, or much of anything else between drum or disc rear brakes. Fair few folks have swapped rear ends for the discs, and that was the extent of the mods, and the brakes worked fine.
Your rear pads should last right around twice as long as the fronts..... Depending on how much you tow/haul. (more weight will allow the rears to do more work.)
Old Nov 1, 2021 | 12:01 AM
AtomicDog's Avatar
AtomicDog
I did the Dana 60 drum brake rear to disc brake rear swap a while ago and had no issues with the swap other than changing the ABS speed sensor on the newer disc brake rear to the 1996 model sensor since it had a different electrical connector than the newer disc brake rear's sensor had. I used the same master cylinder and see no need for any additional proportioning valve. I had changed all of the hard brake lines to stainless steel and the flexible lines to braided versions. The truck definitely brakes better with the new rear disc brakes.
Old Nov 1, 2021 | 12:19 AM
BClark_35's Avatar
BClark_35
Yep I am at the same point as you. Copper hard lines, speed sensor. All that stuff. Have you done anything with the emergency brake though? Haven't figured that out yet and need it before I get an inspection next year
Old Nov 1, 2021 | 01:14 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
Yes, my parking brake setup is connected and working. You will need the rear disc brake style parking brake cables that go to each rear wheel. I installed new rear disc parking brake cables since the old cables weren't in decent condition. Once you have them, they will connect up to the existing parking brake cables/mechanism/adjuster.
The parking brake assembly on the disc brake rear has a set of small brake shoes at each rear wheel that press on the inside of the rear brake rotors when the parking brake is applied.
Old Nov 1, 2021 | 09:18 AM
BClark_35's Avatar
BClark_35
Awesome. I put all new hardware for my parking brake in except for new cables. Guess I will be ordering new cables here soon. Thx
Old Nov 1, 2021 | 04:45 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Just make sure you order the correct length cables for each wheel. They come in different lengths depending upon the truck's length/combo. Take a measurement from each wheel to the parking brake connection point. The cable can be a bit longer than the old one but certainly not too short.
