Heater core or something else
Old Nov 5, 2021 | 02:33 PM
TCarr's Avatar
TCarr
Default Heater core or something else
My 1999 Ram 1500 5.9 doesn't have heat, i can smell antifreeze but it not leaking inside the cab (from what i can tell) it is leaking (not bad just dripping basically) on the passenger side somewhere between the engine and tire (closer to the tire). If I sit in idle for long periods I get like a steam or smoke coming from the vents inside the cab, my window fogs up also. I am going to replace the belt because it squeals at startup and sounds like a cricket almost constantly. Is this the heater core and belt or more?
Old Nov 5, 2021 | 03:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Windows fogging up is a clear indicator of a leaking heater core.
Old Nov 5, 2021 | 09:08 PM
95RAM360's Avatar
95RAM360
Rent a pressure tester and find leak….put your hand on passenger side carpet and feel for any wetness up to firewall
Old Nov 5, 2021 | 09:49 PM
MoparFanatic21
Also be aware that it could be coming out of the AC drain tube and not into the floor. My 98 Durango did that.
Old Nov 6, 2021 | 10:55 AM
Ramman18's Avatar
Ramman18
The heater core sits in a cavity within the HVAC box and won't necessarily leak into the cab. Mine was completely shot and had a nice puddle in there. If your heat is wimpy and windows fog up, time to get that dash apart!
Old Nov 8, 2021 | 02:47 PM
Keith_L's Avatar
Keith_L
You should generally still have heat with a leaking core.
I'd absolutely chase down the leak you see, but I doubt that's the reason for no heat. I'd suspect clogged core or blend door issues
edit: or thermostat stuck open! Just fixed that on a 2000
Old Nov 8, 2021 | 06:55 PM
Being low on coolant will also compromise heater performance.
Old Nov 9, 2021 | 10:08 AM
Ramman18's Avatar
Ramman18
These copper cores don't last forever. I bet if we looked at all our individual cores today they would be more than disgusting. I couldn't believe how bad mine was at 19 years old. I did a big flush back in 17 and that helped a little but the heat was never great. Now I keep it at halfway warm or I'm air fried out of the cab.
Old Jan 8, 2022 | 01:08 AM
96albertaram's Avatar
96albertaram
I wish I had that problem. Just did my heater core. Still barely any good heat
Old Jan 8, 2022 | 08:30 AM
dodgetruck2's Avatar
dodgetruck2
Like mentioned above, could be a blend door issue also, and for anyone looking at replacing the core I highly recommend pulling the dash and heater box apart. I know its more involved but doing things right has a bigger reward. The last one I did the A/C evaporator was plugged up resulting in almost no air flow. Thanks Dodge for not giving us a cabin air filter....
