Speed Limiter
Old Nov 21, 2021 | 03:14 AM
ThatRedRam's Avatar
ThatRedRam
Default Speed Limiter
I have a 1995 Dodge Ram 1500 318 auto. it tops out at 90mph and i know it should have more in it. whats causing it to top out? how can i get get more top speed out of it
Old Nov 21, 2021 | 07:38 AM
95RAM360's Avatar
95RAM360
Have you adjusted your TV cable? This will effect shift points
how many miles? Engine tired?
Old Nov 21, 2021 | 08:33 AM
Likely you just don't have the power to push your 5000+ pound brick any faster thru the air.
I would question why you think you need to go faster than 90 in a pickup truck though..... Its a truck, not a sports car.
Old Nov 21, 2021 | 11:24 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
I must say, in some areas in central VA, if you are doing less than 80 MPH on some stretches of highway, you're likely to get run over or at the very least look like the snail on the road vs. the Fords and Chevys out there. When I do drive my truck on the highway, which I primarily use for hauling odds and ends, its not uncommon for it to see open highway speeds of 80MPH and above from time to time, even pulling a 6x10 utility trailer. I have taken a lot of time to upgrade the front suspension, tires, transmission and engine to help the truck live properly at higher speeds. Since the truck doesn't seem to pass many gas stations anyway, its comforting to know that my 3/4 ton truck can make its way down the highway when needed.
Old Nov 21, 2021 | 12:48 PM
ThatRedRam's Avatar
ThatRedRam
The motor has about 50k miles on it. and the truck is in perfect condition. It red lines at 90mph.
Old Nov 21, 2021 | 12:49 PM
ThatRedRam's Avatar
ThatRedRam
And i race so the limiter of 90mph gotta go
Old Nov 21, 2021 | 01:31 PM
95RAM360's Avatar
95RAM360
Being obd1 it’s not that easy to change limiter….also check your plenum, try to verify cat isn’t getting or is clogged.
my 95 ram with 200k miles did 100+Mph with ease when I was in maine and had to get to Massachusetts because my wife was in labor having our first child…there’s obviously something wrong. You should dig in a bit to find out
Old Nov 21, 2021 | 01:43 PM
ThatRedRam's Avatar
ThatRedRam
I dont have cats or o2 sensors. Theyve been deleted
Old Nov 21, 2021 | 02:09 PM
95RAM360's Avatar
95RAM360
have you done the non fouler method for o2?
my 95 had hollow cat so I doubt it’s that
Old Nov 21, 2021 | 04:40 PM
ol' grouch's Avatar
ol' grouch
What gears are you running? Red line at 90 is pretty low speed. Do you have 3.91 or 4.11 gearing? If so, you're doing good to get 90. My truck is running 3.55 and gets to 90 with ease the few times I've tried and it wasn't near red line.
