Trans Replacement/Upgrade 1997 Cummings
Old Dec 9, 2021 | 08:33 PM
Originally Posted by dodgetruck2
Dodge did some valve body voodoo around 99 also? even a 99 trans wont swap to 2000 IIRC, Solenoid resistances or something?
That's just installing the correct year governor pressure sensor/solenoid, and a clip. The only thing that changed was the resistance of the temp sensor, round vs. square connector on it, and the way the solenoid mounts. (slightly different design) I *think* the range sensor changed in 2000?? To go with the LED PRNDL??? I think the hole it screws into is larger, and the rooster comb inside the trans may be different as well.
Old Dec 9, 2021 | 09:19 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Never had led PRNDL in the second gens. Some late model 2002 got it
Old Dec 10, 2021 | 09:29 AM
I thought the 2000 and up got it?
Old Dec 10, 2021 | 07:30 PM
dodgetruck2's Avatar
dodgetruck2
my 01 still had the same shifter display as 98+ trucks, Ive never had or been around an 02 that was an auto, as in a 2nd gen body, id assume the 02 1500 had the LED shifter/cluster all pre 06 trucks used
Old Dec 10, 2021 | 09:07 PM
MoparFanatic21
Nope. As mentions it's the same as the 98+. Only the late 02 2nd gen got them. I leave for a few days and this forum goes to hell just kidding
