46re oil pressure PSI
Old Dec 11, 2021 | 04:36 PM
Dodgemonkey95's Avatar
Dodgemonkey95
Default 46re oil pressure PSI
Does anyone know how much oil pressure the pump puts out on a 2001 46re?
I'm getting new cooling lines made up and need the pressure rating as well as needing it for an inline gauge I'm planning to install.
Old Dec 11, 2021 | 07:22 PM
Cooler lines are low pressure. Good rubber hose will work. Gauge will be meaningless, as pressure there, has nothing to do with the trans working properly, or not....
Old Dec 11, 2021 | 09:41 PM
Dodgemonkey95
Interesting I did not know that. I thought the pump had to be cycling in order for the trans to shift
Old Dec 11, 2021 | 11:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
There is no pressure readings. If you are getting a Qt and a half in 10 seconds, the pump is working good. This is what was called a flow test by dodge.
Old Dec 12, 2021 | 09:33 AM
Moparite's Avatar
Moparite
You can see the pressures at the different ports.(it's on the last page)
https://www.trucktransdiag.com/downl...nsmissions.pdf
