5.2L magnum 318 in my 99 Ram 1500 4x4 rear main seal leaking
Old 01-06-2022, 05:39 PM
AmpMan's Avatar
AmpMan
AmpMan is offline
Default 5.2L magnum 318 in my 99 Ram 1500 4x4 rear main seal leaking
5.2L magnum 318 in my 99 Ram 1500 4x4 rear main seal leaking. I replaced it twice and the oil pan gasket. STILL leaking. I can’t figure out why!? Someone help?!
Old 01-06-2022, 06:53 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
I can't help. I did my rear seal a few years ago and it leaks exactly the same as it did before. Same with the front main. In my experience, once something leaks, it forever leaks.
You could try one of those "miracle" bottles of snake juice that claims to stop rear seal leaks from autozone.
Old 01-06-2022, 09:21 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Are you sure it's coming from the rear main? And not just running down from somewhere else??
Old 01-06-2022, 09:25 PM
Keith_L's Avatar
Keith_L
Keith_L is offline
This, or front pump seal. But obviously that's ATF
Groove in crank from old seal? New seal seated perfectly square?
Old 01-06-2022, 11:21 PM
AmpMan's Avatar
AmpMan
AmpMan is offline
yea it’s pretty aggravating. My front main is good but that rear is not sealing for me
Old 01-06-2022, 11:24 PM
AmpMan's Avatar
AmpMan
AmpMan is offline
yes I’m pretty sure. Right in between the motor and trans and if I park nose down on a slanted road it doesn’t really leak since most of the oil is in the front of the pan. I also checked the oil pressure sensor that’s above and it’s dry.
Old 01-06-2022, 11:26 PM
AmpMan's Avatar
AmpMan
AmpMan is offline
it’s gotta be a groove! I’m doing this job without moving my motor or trans. After removing a refrigerant line bracket, I can finagle the oil pan right out of there (4x4). The bottom side is the only side I could see. Didn’t appear to be a groove though
Old 01-07-2022, 12:12 AM
Keith_L's Avatar
Keith_L
Keith_L is offline
You could detect a groove with your fingernail...
It is possible to install the RMS backwards-- you got it oriented correctly? And did you do a little silicone on the corners of the bearing cap before reinstalling?
Apologies on asking about square, I forgot Dodge uses a 2pc rear main ala GM
Old 01-07-2022, 05:16 AM
AmpMan's Avatar
AmpMan
AmpMan is offline
now, the first time I replaced it, I think I did have it backwards. But the second time for sure I had it right. I used silicone as well. Very small amount of red rtv. Not sure if that is the best for this application but that’s what I keep the same on my truck so I used it.
Old 01-07-2022, 06:58 AM
HeyYou is offline
Did you lube the new seal good before installation? Putting it in dry pretty much assures it will start leaking in short order.
Quick Reply: 5.2L magnum 318 in my 99 Ram 1500 4x4 rear main seal leaking
