360 or 318 for High Horsepower build
01-12-2022, 08:08 PM
Dodge Forum Administrator
You will have to re-pin some connectors, and run the wiring for the data port, but, the rest will work find.
01-12-2022, 08:09 PM
01-12-2022, 08:12 PM
OBDII connector. On the OBDI trucks, it's under the hood, by the PCM. On the newer trucks, it's under the dash, between the drivers knees.
01-12-2022, 08:28 PM
I have a connector under my dash exactly where you explained but its a 1995. Has it already been swapped!!
01-12-2022, 09:02 PM
Have a look at the PCM, if there are three connectors on it, it's obdii, of there is only one big one, it's obdi.
01-13-2022, 06:42 AM
okay so there is only 1 connector on it so whats the hook up under my dash doing there
01-13-2022, 07:13 AM
Good question. Can you trace the wires, see where they go?
What color is the connector??
01-13-2022, 07:24 AM
it is black and its mounted as if its for a computer scanner for like a obd2. Ill trace it back when its gets a little warmer outside later today
01-13-2022, 07:33 AM
01-13-2022, 07:45 AM
Yes i will as soon as i can
