No crank & 2 Possible Missing relays
Old Jan 15, 2022 | 03:59 AM
Sinexay's Avatar
Sinexay
Default No crank & 2 Possible Missing relays
98 1500 5.9 auto
truck previously slid off iced road found 2 relays on the ground don’t know where they go.
Symptoms: truck won’t crank
Slight damage on driver side;bumper/headlight&corner light/ (have parts)
front driver and rear driver tires blown.(fixed)
knocked shift rod out of adjustment (fixed)
Scanned obd port for codes and it showed only P1899 and I’ve replaced the park/neutral safety switch(fixed)
Abs and brake light showing on dash; brake pedal stiff
Old Jan 15, 2022 | 05:17 AM
Dodgetech1990's Avatar
Dodgetech1990
Battery fully charged?
Old Jan 15, 2022 | 09:39 AM
Look in the PDC, see which relays are missing.....
Old Jan 15, 2022 | 03:10 PM
Sinexay's Avatar
Sinexay
Old Jan 15, 2022 | 03:11 PM
Sinexay's Avatar
Sinexay
Are there any relays under the car near bumper or fender that would keep car from starting?
Old Jan 15, 2022 | 03:30 PM
Nope.
Starting circuit is pretty simple. Ignition switch passes current to the relay in the PDC, from there, it goes thru the neutral safety switch, to ground. So, turning the key really only engages the relay. The relay gets power on pin 30, when the relay is activated, it closes the circuit between pin 30, and pin 87. Pin 87 is the wire that actually runs down to the starter solenoid. If the starter relay isn't there, the truck won't start. If the Neutral safety switch is bad, the truck won't start. If the trans isn't in park, or neutral, the truck won't start.
There should be a diagram on the cover of the PDC, which tells you which fuses/relays do what. Make sure it isn't the starter relay that fell out.
Old Jan 15, 2022 | 03:41 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Given that you had to adjust the shifter rod on that truck due to the accident, might want to try starting the truck in neutral to see if that does it. Try jiggling the shifter slightly before neutral and slightly after neutral while holding the key to 'start' to see if it will allow the starter to turn due to the neutral safety switch being engaged properly.
Old Jan 15, 2022 | 03:48 PM
Sinexay's Avatar
Sinexay
Nope.
Got it started! Thanks for the hint. It was missing the starter relay. It starts then it started making a loud air/hissing noise and started acting kinda of rough.
Old Jan 15, 2022 | 03:51 PM
Sinexay's Avatar
Sinexay
Default Hose
what does this hose go to? It’s coming out of the driver side firewall dangling unhooked by the driver side fender
Old Jan 15, 2022 | 03:56 PM
Sinexay's Avatar
Sinexay
got it started! Somehow the starter relay was missing. I’m not sure if it was one of the 2 relays that was found on the ground though.. would seem weird for it to pop out the top of the socket like that but hey it’s possible..
