Passenger brake light out
Old Jan 26, 2022 | 08:58 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Haulmonster58
When testing this area, where is the other end of the tester supposed to connect to ?
A good ground. Or power. I usually run a wire from the battery to where I am working.
Old Jan 27, 2022 | 06:12 AM
Haulmonster58's Avatar
Haulmonster58
What type of wire ?
When testing the brake connector, am I testing for power , ground or both ?
Old Jan 27, 2022 | 09:53 AM
MoparFanatic21
What type of wire ?
Any wire. You are testing for both but since you only have one thing not working, I would say the ground is good. You are just missing power. If you don't have power you can split the harness. Up by the drivers side wheel (behind fender liner on the bottom of the cab) is a connector. Try to see if you have power there if you don't back at the brake light.
Old Feb 15, 2022 | 04:11 PM
Haulmonster58
Finally checked my brake light.. It seems I don't have power going to the light/socket. Whats the quickest and easiest way to fix this ? Light being out is becoming a pain
Old Feb 15, 2022 | 05:28 PM
MoparFanatic21
Check for a broken wire somewhere.
Old Feb 15, 2022 | 07:27 PM
Does the turn signal work?
Old Feb 15, 2022 | 09:45 PM
Haulmonster58
No it doesn't . The other signals work fine
Old Feb 15, 2022 | 10:36 PM
AtomicDog's Avatar
AtomicDog
Just looking at your photos, the bottom socket looks like the prongs for the bulb might be missing or too wide/loose. This could also be a bad photo of the connector, but thought I'd mention it.
Old Feb 15, 2022 | 10:49 PM
Haulmonster58
Do you know what the bottom socket is linked to ? Brake light, tail light, turn signal or reverse light ?
Old Feb 16, 2022 | 12:13 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
Not sure, but it looked like the metal bulb contacts were either non-existent or very wide, but that could have been the way the photo was taken. If you don't get good contact within the bulb socket, it certainly won't light up.
