Passenger brake light out
Old Feb 16, 2022 | 09:43 AM
  #21
Haulmonster58's Avatar
Haulmonster58
Originally Posted by AtomicDog
Not sure, but it looked like the metal bulb contacts were either non-existent or very wide, but that could have been the way the photo was taken. If you don't get good contact within the bulb socket, it certainly won't light up.
I see 4 metal contacts in the top socket.. Should the bottom socket have the same number of metal contacts ? This is something I noticed but thought this is how they were made.
Old Feb 16, 2022 | 11:03 AM
  #22
AtomicDog's Avatar
AtomicDog
Lightbulb
I'd suspect they should be the same. You can check the other side to be certain.
Old Feb 16, 2022 | 12:05 PM
  #23
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No as the bottom socket only needs two contacts (power and ground) where the top needs 4 (ground, park lights, turn signal, and brake light).
Old Feb 16, 2022 | 04:22 PM
  #24
Haulmonster58
Do you think replacing the the tail light wiring harness will fix this issue ? Ive found out there is no power going to the socket that goes to the brake light
Old Feb 16, 2022 | 11:37 PM
  #25
MoparFanatic21
Check at the plug farther down to see if you have power there.
Old Feb 17, 2022 | 07:46 AM
  #26
If you have a trailer harness on your truck, that is a spot that is notorious for corrosion/broken wires, etc. The connections there just weren't the best.
