Tranny and diff upgrades
Old Feb 12, 2022 | 10:43 AM
HD Kowboi's Avatar
HD Kowboi
Default Tranny and diff upgrades
I have a 2001 ram 1500 2wd with 3.55 rear gears. I'm about to have the tranny rebuilt next week, its pushing 2k miles and slipping bad. I'd also like to go with 3.92 gears in the back but I'm not sure what all I need to get the job done. The shop will do the rear end work but I need to supply parts. What all do I need?
Old Feb 12, 2022 | 11:57 AM
I would go with gears, (Yukon, or USA gear) and a master rebuild kit. Comes with all the bearings and seals you need for the install.
Old Feb 12, 2022 | 12:01 PM
Keith_L's Avatar
Keith_L
The 9.25 doesn't have carrier breaks so you'll just need gearset of your choice (I'd try for Yukon thru Randy's) and install kit. Make sure your kit has all new carrier bearings and pinion bearings.
Also a good time to do wheel bearings and wheel seals and possibly drum brake shoes/hardware if warranted. All this stuff is optional, it's up to you.
Of course you'll need a couple quarts of gear oil if you're supplying everything.
If you really want a TAD (traction aiding differential) and don't already have the limited grip....er slip....now's the time but it'll increase cost considerably. If you already have the factory limited grip you'll want the parts to rebuild that, too...assuming you want to keep it and not replace with something better like a TruTrac. You'll want to know if you already have the limited grip when ordering parts. Or looks like a TrueTrac runs ~$600
https://www.jegs.com/i/Detroit-TrueT...3A368/10002/-1
If you have factory open diff and just want to keep that you won't need anything additional in that regard unless you get into it and find your spider and/or side gears are chewed up
Old Feb 12, 2022 | 12:13 PM
95RAM360's Avatar
95RAM360
Instead of rebuilding your trans why don’t you nv3500 swap it then you’ll never have trans issues (aside from when clutch needs replacement) it’ll be about the same cost…
Old Feb 12, 2022 | 02:46 PM
Keith_L's Avatar
Keith_L
Also, if realtors can't call it a master bedroom anymore pretty sure it's not a master install kit. Geez dude, soooo offensive!!
Old Feb 13, 2022 | 10:20 AM
Terribly sorry, I am taking meds to kill off my 'political correctness'.
Old Feb 13, 2022 | 05:27 PM
Spillage's Avatar
Spillage
Originally Posted by Keith_L;[url=tel:3537355
3537355[/url]]Also, if realtors can't call it a master bedroom anymore pretty sure it's not a master install kit. Geez dude, soooo offensive!!
I know… what’s going to happen when someone mentions mud-flaps
Old Feb 13, 2022 | 07:23 PM
Keith_L's Avatar
Keith_L
Actually I'm wondering about ASE "master techs"
Sorry, just deeper into the weeds
Apologies to OP for derailing your thread!
Old Feb 14, 2022 | 09:05 PM
00t444e's Avatar
00t444e
I would go with 4.10 gears and a Detroit Truetrac in the rear.
Old Feb 15, 2022 | 05:02 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Detroit Truetrac and gear ratio according to size of tire/wheel you will be using, and a (master) rebuild kit. If you plan on drifting, an air locker, ARB or Yukon Grizzly, would be nice so both axles are locked together while drifting then turn it off for an open diff on the road. I rebuilt my trans with many performance parts. Get a shift kit (https://www.sonnax.com/sure_cure) put in while it's getting a rebuild, it wakes the trans up.
A tidbit of information,
The OEM gear-type LSDs (A couple of different mfg) will typically have a lower Torque Bias Ratio (TBR) than an aftermarket gear-type automatic torque biasing (ATB) differential. The torque bias ratio represents the amount of torque that is sent to the wheel with superior traction when one wheel encounters a slippery situation. Higher TBR values will help get more net power to the ground in these circumstances, look up Torque Bias Ratio to delve further on how posi/LS work
