No odometer
Old Feb 20, 2022 | 04:22 PM
LanceMac's Avatar
LanceMac
Default No odometer
A friend of mine has a 2000 ram and she had a motor swap done to it we had the no bus code but now I have no odometer at all what could be the problem
Old Feb 21, 2022 | 05:40 AM
95RAM360's Avatar
95RAM360
Was the engine pre 1998 or 1998 later? Was it a 5.2 and you put a 5.9 in it? Need a little more info
Old Feb 21, 2022 | 07:00 AM
Does the speedometer still work?
Old Feb 21, 2022 | 03:21 PM
LanceMac's Avatar
LanceMac
I figured it out but the no bus code came back on and it's a 2000 with a 5-2 and a 5-2 is what came out of it
Old Feb 21, 2022 | 03:26 PM
That generally implies something on the 5 volt bus has an issue. Trouble is, there is a LOT of stuff that uses that 5 volt signal, and one of 'em shorting out somewhere takes the whole thing down. You can try unplugging sensors one at a time, and see when the bus comes back. (unplug with ignition off, turn ignition to 'run', (not start) see if it works now, if not, move on to another sensor, if it does, the last one you unplugged is the issue.)
Old Feb 21, 2022 | 03:31 PM
LanceMac's Avatar
LanceMac
Yeah it's not even letting it crank over
Old Feb 21, 2022 | 04:45 PM
Then you have more than one problem.
Old Feb 21, 2022 | 07:04 PM
AtomicDog's Avatar
AtomicDog
Since it won't even crank, have you checked your battery to ensure that its fully charged? The other thing you can try is to put the truck in neutral and try to start it.
Old Feb 21, 2022 | 08:13 PM
LanceMac's Avatar
LanceMac
I think the neutral safety switch needs to be replaced
Old Feb 22, 2022 | 12:38 AM
AtomicDog's Avatar
AtomicDog
Did it crank after putting the truck in neutral? If so, the shifter linkage may need adjusting or possibly the neutral safety switch might be bad..
