Acceleration Issues
Old Mar 16, 2022 | 04:28 PM
If it shakes while sitting still, in neutral, that is an engine miss. When was the last time plugs/wires/cap/rotor were changed? Is you plenum gasket blown?
Old Mar 16, 2022 | 06:32 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by KameronG7
Yeah it shakes while in neutral
That narrows things down quite a bit. Either a weight has come off your flex plate or you have a miss in the engine.
Old Mar 16, 2022 | 08:59 PM
95RAM360's Avatar
95RAM360
I was going to say transmission mount….mine just went cuz rubber separated completely from the metal so it was floating around and causing similar issue
Old Mar 17, 2022 | 03:41 PM
KameronG7's Avatar
KameronG7
How do I know for sure if a weight has come off the flex plate?
Old Mar 17, 2022 | 06:18 PM
ol' grouch's Avatar
ol' grouch
Under the truck, right where the engine and transmission meet, there will be a little plate to protect the flex plate from the weather and road debris. There should be 4 or 6 little bolts holding it in place. Removing them will let the plate drop. You'll notice little weights around it. The method of balancing changed around then but where the weights are welded, you'll see some welds that aren't holding anything. Other places they will be holding a piece of metal.
It's not very common for the weights to fall off. You may just have a bad plug wire or an injector not working properly causing a misfire.
Old Mar 17, 2022 | 07:25 PM
Think ya need to pull the starter to remove that plate as well, but, it's been a while, so, I could be wrong.
Old Mar 17, 2022 | 07:53 PM
ol' grouch's Avatar
ol' grouch
You may be right. It's been quite a while since I was under one of these and then I was getting ready to pull the engine/transmission assembly.
Old Mar 17, 2022 | 10:34 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
HeyYou is correct starter has to be pulled
