Acceleration Issues
Old Mar 14, 2022 | 09:37 PM
KameronG7's Avatar
KameronG7
Default Acceleration Issues
I've got a 98 ram 5.2L and I'm not sure if these problems go hand in hand or not.. but I don't think it accelerates as fast as it should, I feel like there should be a little more get up and go but it just doesn't have it.. is this common? The other problem is a very intense shaking when I'm driving and keeping the pedal at a steady position, but slowing down or accelerating faster stops the shaking.. anyone know the reasons for these?
Old Mar 15, 2022 | 09:40 AM
Does the shaking get significantly worse above 40 mph?
Old Mar 15, 2022 | 10:29 AM
ol' grouch's Avatar
ol' grouch
Well, your post is a bit amorphous. (<---- a fancy word I used because I feel like being a snot today. ) The first thing to come to mind is worn or seizing universal joints in the drive shaft. However, a lot depends on how it shakes. Does the whole truck shake? Does it feel like it coming from the front? Rear? Are your tires wearing oddly? Does it go away or get worse when you step on the brakes?
It sounds like it's in your driveshaft, but there are a LOT of other things it could be. So let us all know more details so we can help you.
Old Mar 15, 2022 | 01:41 PM
KameronG7's Avatar
KameronG7
The shaking basically goes away while it's in overdrive but it's still there a bit, I guess if the shaking is coming from anywhere then it's the front of the vehicle
Old Mar 15, 2022 | 02:29 PM
Is it speed related? If you drop out of O/D, does it start shaking?
Old Mar 16, 2022 | 07:57 AM
KameronG7's Avatar
KameronG7
Yes the shaking will get worse if overdrive is turned off, but it still will go away by slowing down or going faster.. but when it does shake it's alot worse when overdrive is off
Old Mar 16, 2022 | 08:51 AM
Thats just weird. How are your tires? Have you tried rotating them, and see if anything changes?
Old Mar 16, 2022 | 09:15 AM
ol' grouch's Avatar
ol' grouch
If you are sitting in neutral, is there any shake? How about if you race the engine?
Old Mar 16, 2022 | 09:16 AM
Keith_L's Avatar
Keith_L
Sounds like misfire or TPS to me.
Pull codes including pending codes
Old Mar 16, 2022 | 03:50 PM
KameronG7's Avatar
KameronG7
Yeah it shakes while in neutral
