Trans/T Case Clunk
2000 Ram 1500 46re 4wd. It's making clunk when I go from reverse to drive. Also when I accelerate from a stop. Definitely sounds like the t case area. It's just a single clunk. Drives fine. Here is a video going from reverse to drive. Both rear u joint just replaced. I'm hoping at worse just the t case. Used ones are relatively cheap and I've already replaced it once 🙃 https://youtube.com/shorts/x8AcT51--o4?feature=share
There is a fair bit of slop in the driveline.... between the t-case, the rear diff, a bit of a clunk when putting it in gear, or changing from reverse, to drive, or vice versa, isn't unusual.
the only part that concerns me is when I take off from a stop and it makes the noise. Did you listen to the video? It's pretty audible. If I had to guess it's slop in the t case chain. Can't really think of much else it could be. Don't know enough about automatic transmissions.
It's fairly pronounced in your vid... should be pretty easy to localize that to where it is coming from. Watch the rear driveshaft, see how much if moves when you put it in gear.
Yea unfortunately it is a bit pronounced. I was sitting next to a car so it made it even louder. It's definitely does not sound like the rear differential area. I know when I had the driveshaft out for the u joint there was some slop when it was in park but I thought that was normal. About the same slop as my Jeep had. I did replace the pinion seal months ago but I was very careful getting it back where it was. Maybe it came loose but I'll have to check. Still feel it's in the t case
I put a t case saver kit in there when I put the used t case in. I'll get under and look after work. One time when I was justndown there a trans mount bolt came loose so maybe it came loose again. Or I'll end up pulling my driveshafy for the 8th time in 7 months.... ugh
Trending Topics
The chain really isn't doing anything when you are on the road. It's just basically along for the ride. Most of the slop is in the gears in the t-case, and the rear diff. It's fairly pronounced in your vid... should be pretty easy to localize that to where it is coming from. Watch the rear driveshaft, see how much if moves when you put it in gear.
