99 Ram 1500 starts and dies almost immediately
Hi there,
I’ve been in extreme need of help. I’ve been chasing this problem around for over a year now. When it first stopped running the night before it would sputter then buck and sometimes would stutter and die. I’ve replaced the plenum gasket with the Hughes engines replacement kit and well as changing the IAT Sensor, the IAC sensor, throttle position sensor, distributor cap, rotor, spark plugs, pcm, instrument cluster, and both upstream and downstream O2 sensors. I’m at a loss honestly. I just want my truck back up and running please somebody help.
How is fuel pressure? And I hope those were genuine mopar sensors. These engines really don't like the aftermarket fellers. Sometimes you introduce more problems than you were trying to solve. Especially with the IAC..... (cam and crank sensors are also rather critical, and you shouldn't use ANY aftermarket parts there.)
So I went out today and started it. It ran for about 3-4 minutes then randomly shut off. Yesterday when it was running it was rather immediate. I ended up starting it back up and when I was sitting there going through the gears it stalled as soon as I put it in neutral. Not quite sure what that means, but hopefully someone will know.
Trending Topics
