Full throttle no 1-2 shift
Old Apr 12, 2022 | 10:55 PM
Dave Meldrum's Avatar
Dave Meldrum
Default Full throttle no 1-2 shift
Running a 98 2wd 1500. 5.9 gas 46re transmission. driving around normal it shifts fine. But if you take off from idle full throttle it won't shift from 1st to 2nd unless you let off the throttle. Ive changed governor pressure sensor, checked tv cable adjustment.
anybody on here ever had that problem and how did you fix it?
Old Apr 13, 2022 | 12:50 AM
master tech's Avatar
master tech
Site Moderator & Tech
At what speed do you need to back off the throttle? If the problem was 2nd to 3rd gear I would say its the transmission seals. 1st to 2nd in most cases is a kick down problem.
Old Apr 13, 2022 | 09:10 AM
Didn't the pressure sensors have issues at WOT on these??
Old Apr 13, 2022 | 11:09 AM
master tech
Could a valve hanging up in the valve body or even the TPS is out of range.
Old Apr 13, 2022 | 08:49 PM
Dave Meldrum
it will go past 5500rpm and start floating the valves. But with regular driving it shifts fine.
Old Apr 19, 2022 | 01:16 AM
master tech
I'm guessing you have harden transmission seals. You could try a seal softer in the transmission.
Old Apr 19, 2022 | 07:55 AM
Dave Meldrum
I had the trans rebuilt in 2017 so I'm pretty sure that's nit the problem. I removed the valve body thinking that perhaps the 1-2 shift valve spring broke but it was fine. Upon inspection of the valve body I did notice 4 screws loose that hold the valve body together were loose. They were hand tight. Once the weather cleans up and I can get back underneath the truck I'll reassemble everything and hopefully that's what the problem is.
Old Apr 19, 2022 | 02:53 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
While your under there replace filter and adjust bands.
Old Apr 19, 2022 | 05:08 PM
master tech
Let us know if the fix the problem. I hope that did as well.
Old Apr 29, 2022 | 02:30 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
When I rebuilt my transmission, first time anyone was in there at 85-86K miles, I had 3 loose bolts in my valve body. 1 about 3/4 inch out, 1 about 2 threads loose, and the other hand tight, all 3 were on the driver side of the VB. Burnt FWD Drum Clutch Pack and Burnt OD Unit Clutch Pack. I think the loose screws were the problem for the burnt clutch packs.
