Vibration/shudder at idle?
Old Apr 20, 2022 | 09:07 PM
Liddlez's Avatar
Liddlez
Default Vibration/shudder at idle?
I’m getting a vibration that’s mostly noticeable in front end, and I’ve exhausted every diagnosis. I’ve replaced the cap, wires, plugs, (she was due for) idle air control valve, and TPS. It’s not a harsh vibration, but it’s still noticeable. She runs smoothly while driving. Any ideas would be greatly appreciated! I’ve also smoke tested her, and no leaks. The only smoke comes out of the throttle body butterfly which is normal, I’m told.
Old Apr 20, 2022 | 11:08 PM
95RAM360's Avatar
95RAM360
Your plenums blown….take a flashlight and look into intake, see any oil? Shouldn’t be there… If so plenum gone…that smoke test was also an indication
Bad plenum can clog cat, in turn screwing with o2 sensor, which can effect ignition components
Old Apr 20, 2022 | 11:12 PM
Liddlez's Avatar
Liddlez
Definitely not blown. I ran all the tests. No pooling of oil, or vacuum in the valve covers.
Old Apr 20, 2022 | 11:23 PM
95RAM360's Avatar
95RAM360
Did you route the wires according to the TSB? There’s a certain way to route because wire arcing can happen
and you did look into the intake right? You’d need a flashlight…..this is a design issue, it will blow, they all do
Old Apr 20, 2022 | 11:31 PM
Liddlez's Avatar
Liddlez
Yes I did. Again, no pooling. I know that because I had the Hughes plenum repair kit installed a while ago.
This is my routing. I followed the FSM.
Old Apr 21, 2022 | 05:42 AM
95RAM360's Avatar
95RAM360
There’s a TSB (technical service bulletin) that the manufacturer released….the wire ends aren’t what I’m talking about, it’s how you route the wires to the plug
Old Apr 21, 2022 | 06:30 AM
Moparite's Avatar
Moparite
What plugs did you put in?
Old Apr 21, 2022 | 08:26 AM
AtomicDog's Avatar
AtomicDog
And, when you replaced the idle air control valve, did you clean out all of the carbon/muck in the throttle body well area before replacing the valve?
Old Apr 21, 2022 | 01:22 PM
Liddlez's Avatar
Liddlez
Champion copper plus.
Liddlez's Avatar
Liddlez
Yes, I did.
