Attempting to replace the shift seal
Hi guys, im new to the forum but browse a lot on here for years now Had a question that perhaps someone can shed some light on for me. I started the process of replacing the shift shaft seal on my 2000 Dodge Ram 2500 4x4 gasser and its day 3 with the seal refusing to pop out at all. Now i have the removal tool (which hardly does anything useful) and was trying to use everything from flathead screwdrivers to seal pullers and so far the most progress i made was a handful of trans fluid on the ground and part of the rubber sticking out but the seal itself is still flush with the trans housing. I was wondering as a last resort option of maybe using a 90 degree impact on the removal tool while pressing it down would get it to bite and finally yank this thing out. Im out of options and all my mechanics in town are booked for well over 3 weeks and id prefer to get her running sooner rather than a month down the road. Might try to get some pictures once im off work. Any advice is appreciated. Thanks.
Trending Topics
Do you happen to know if that same removal tool works for the 46RE/727 style transmission selector shafts?
This tool may also be helpful to remove that seal - https://www.lislecorp.com/specialty-...pe-seal-puller
I have a magnetic worklight under there and im glad i got that makes life much easier when your not having to wedge a flashlight in there I do have both that seal tool and the puller as well but either seemed to budge it at all. I was contemplating dropping the pan and valve body anyway as the previous owner did not do a good job on the pan gasket anyway, just a lot of extra work to punch out a little seal. If i go that route though will i be able to punch it out with a flathead from the inside out? I dont want to damage anything but if all else fails ill either try to limp her down to my local trans shop Monday or tow it depending how much fluid tries getting out while driving. Only benefit is that i could replace the filter while im in there which im wondering if its the original one anyway.
