Acceleration issues
Old May 23, 2022 | 08:18 PM
needzhelp's Avatar
needzhelp
Default Acceleration issues
I’m having issues when I give it gas just don’t seem to want to get up to speed don’t have a clue we’re to start tried ready on here no luck some one give me like a check list I can start with
Old May 23, 2022 | 08:31 PM
AtomicDog's Avatar
AtomicDog
Has any maintenance been done on this truck at all? What year, make, model and type of engine/transmission truck are you referring to? Is the check engine light on? If so, has it been scanned for any codes?
Old May 23, 2022 | 08:43 PM
needzhelp's Avatar
needzhelp
Default Reply
I did the plugs and wires yesterday it’s a v8 I bought it last week ram 1500 2001 it sat for years befor I got it it has 129000 miles and no check engine light sorry I know nothing about working on vehicles but I am capable so any help would be great
Old May 23, 2022 | 08:46 PM
AtomicDog's Avatar
AtomicDog
Was the truck running well before you changed the spark plugs and wires? What type of spark plugs did you install? These trucks tend to run well on basic copper plugs and not as well using other types of plugs (platinum, etc.). Is the motor a 5.2 magnum or a 5.9 magnum?
Old May 23, 2022 | 08:54 PM
needzhelp's Avatar
needzhelp
Default Reply
No it was still really sluggish before the change used Ngk plugs it’s the 5.2
Old May 23, 2022 | 09:07 PM
AtomicDog's Avatar
AtomicDog
First off, if you are smelling gas, there is likely a leak somewhere. Start the truck, open the hood and closely inspect the fuel lines and fuel rails while the truck is running. You might also want to check to determine what the fuel pressure is at the injectors, as there should be a port on the fuel rail to connect a fuel pressure test gauge.
Since the truck has been sitting for a while, it's likely in need of basic maintenance. In addition to the spark plugs and spark plug wire changes, you should also consider replacing the distributor cap and rotor. Another item that could be contributing to your acceleration issue is a plugged up catalytic converter and/or a blown intake plenum gasket. You can check for a bad catalytic converter by temporarily removing the upstream O2 sensor and see if the truck revs up any better than before. You can check for a bad intake plenum gasket by looking down the intake throttle body (blades fully open) with a flashlight to see if any oil is pooling at the bottom of the intake manifold (see this link for more information - https://dodgeforum.com/forum/2nd-gen...um-thread.html). Lastly, a new timing chain is likely needed at some point, too. The replacement should be a good double roller timing chain and gear set.
Old May 23, 2022 | 09:15 PM
needzhelp's Avatar
needzhelp
Ok that’s were I’ll start I do wanna say that the motor revs fine it seems it’s just when I take off and drive when you notice the lack of power
Old May 23, 2022 | 10:12 PM
Is it starting off in second gear?? Is the check engine lite on??
Old May 23, 2022 | 11:35 PM
AtomicDog's Avatar
AtomicDog
One last item - does the check engine light come on when the key is turned to 'on', then go off once the engine is started? I ask, as sometimes a prior owner will have removed the check engine light bulb.
Old May 24, 2022 | 06:46 AM
needzhelp's Avatar
needzhelp
starts off in first no engine light
QUOTE=HeyYou;3544601]Is it starting off in second gear?? Is the check engine lite on??[/QUOTE]
