I am new here and my login is lumpinator
I am new here and my login name is Lumpinator. I have a 98 dodge ram quad cab 1500 with 5.9 L motor and RE 46 transmission. Just replaced transmission and have a few connections on the
transfer case that I’m not sure about. Any info would be great. Thanks.
They go to the vacuum switch on top of the t-case. Four lines, white is source vacuum from up top, green is a vent line, red and black go the actuator on the front axle. Looks like that vacuum harness has already been hacked to an extent, you can still get new ones though.
Welcome to DF! Moving this to second gen ram section for ya.
Thanks. The one in red is coming straight out of transfer case and just shooting straight up into the air. I was told it was a vent but it looks like it should be plugged into something. The vacuum with four hoses on it is already connected all the way through. The one circled in yellow looks like it should have another vacuum plugged into it but the rubber is torn. Maybe that’s where the one circled in red goes. And thanks for moving me to the right place. I’m new on this. This is the second time I’ve pulled this transmission out. You would think I would’ve taken pictures like I usually do but I didn’t on this one. My mistake.
Trending Topics
