97 dodge ram 1500 5.9L difficult start
Old May 29, 2022 | 04:43 PM
ggrigsby77's Avatar
ggrigsby77
Exclamation 97 dodge ram 1500 5.9L difficult start
So I have a 97 dodge ram 1500 spirt 5.9L
recently this issue has gotten worse. I'll turn the key and get power but when I go to turn it over nothing happens. No clicks no nothing. I'll usually fidget with the key back.and forth and after a few attempts I can get it to start. And when it does decide to start it starts right up no issue. However I couldn't get it to start for two days. Battery, alternator have been checked and only a couple years old. Starter is brand new. Still having issues. Please advise
Old May 29, 2022 | 04:45 PM
If you wiggle the shifter does that improve its attitude?
Also might try swapping the starter relay for the horn relay, see if that helps.
Old May 29, 2022 | 05:23 PM
ggrigsby77's Avatar
ggrigsby77
I never really messed with the shifter in my attempts but I'll try switching the relays!
Old May 29, 2022 | 05:45 PM
ggrigsby77's Avatar
ggrigsby77
swapped the relays and not much luck
Old May 29, 2022 | 10:33 PM
Do you hear the relay click when you turn the key to start? If not, try starting in neutral.
Old Jun 1, 2022 | 12:56 PM
98Ramboy's Avatar
98Ramboy
I don't know about you guys, but I seem to always have to reseat my battery connection every 8-12 mo or so. I'll have this same problem and it'll be the connections to the battery post that end up doing it for me.
Old Jun 1, 2022 | 02:23 PM
ggrigsby77's Avatar
ggrigsby77
Yeah I tried that and it didn't really change much. But now however when I get the starter to kick on it has a hard time starting. Where as before once the starter kicked on it started right up. It now has a new starter and relay. Battery was tested and it good. Checked grounds and cleaned them. Still having issues
Old Jun 1, 2022 | 02:46 PM
Starter draw test? (local parts store should be able to do that for you.)
Starter grounds thru the engine/trans, did you clean the mounting surface really well?
Old Jun 1, 2022 | 02:52 PM
ggrigsby77's Avatar
ggrigsby77
Yes I cleaned all that up but haven't done the starter draw test
