Loud airy sound
Old Jun 3, 2022 | 06:31 PM
Njmiller's Avatar
Njmiller
Default Loud airy sound
Got a 2001 Dodge Ram 1500 with the 5.9 V8 Magnum.
Making a really airy sound and wanted to know if anyone knows what it maybe.
Thinking the AC compressor pulley is bad because it stops making the noise if I lube the belt but the ac compressor pulley slows down almost to a complete stop for a few seconds.
Old Jun 3, 2022 | 10:41 PM
Don't lubricate the belt..... not good for it, or the engine-driven accessories.
Take the belt off, spin all pulleys by hand. See what you find.
ol' grouch's Avatar
ol' grouch
The fan on my '96 sometimes makes a loud noise like an airplane propeller. Don't lube your belt. Oil rots rubber and causes slippage like you've noticed.
Old Jun 3, 2022 | 11:59 PM
Njmiller's Avatar
Njmiller
Default Thanks
Guy I know said lube was best way to diagnose it but I guess I shouldn’t have listened to him haha. Thank you all
Old Jun 4, 2022 | 07:26 AM
Moparite's Avatar
Moparite
Have no idea what a "airy" sound is but from what you describe it may be the belt. I have sprayed brake clean on belts and it will stop the squeak until it dries. Another way of testing instead of spraying lubricants on it. If it's a bad bearing that's another story.
Old Jun 4, 2022 | 01:04 PM
Njmiller's Avatar
Njmiller
Default Solved
Turns out it was the AC compressor pulley, the bearing was terrible got it replaced and put on a new belt and sounds normal now
