Weird noise from rear
Old Jun 20, 2022 | 12:17 PM
Jake72700's Avatar
Jake72700
Default Weird noise from rear
Noticed when driving hearing like an almost brake noise. Not so much a grinding. Hear it when driving, coasting, and braking. Almost sounds like when brake pads get low on life. Was wondering if the shoes could be just low on life and making contact with the drum even when not using the brakes. Doesn’t sound like a bearing is going bad. I’m open to suggestions. Currently at work and haven’t been able to take a look at the rear.
Old Jun 20, 2022 | 01:23 PM
Wouldn't hurt to pull the drums, and see what's up.
Old Jun 20, 2022 | 02:10 PM
Keith_L's Avatar
Keith_L
If it doesn't change with the application of the brakes I would say brakes are unlikely....but indeed it's easy to pull the drums
Old Jun 20, 2022 | 02:21 PM
Jake72700's Avatar
Jake72700
The sound looks like it’s coming from both sides too. And I haven’t changed the drums since I got the truck and been over 50k miles
Old Jun 20, 2022 | 08:48 PM
ol' grouch's Avatar
ol' grouch
50,000 miles is a lot for brakes and you don't know how long they had been run before you got the truck. The brake shoes may be blistered.
Old Jun 20, 2022 | 09:00 PM
Jake72700's Avatar
Jake72700
I got the truck from my grandpa back in high school. But I ended up replacing the brake shoes, the springs, wheel cylinders, and the adjuster just to have all new brake shoes. But the problem was the backing plate has like a channel that goes all the way around. It rusted and was bent causing it to scrap against the drum. Just cleaned up the rust and cut where it was rubbing and now brakes like new again.
Old Jun 20, 2022 | 11:38 PM
cytuss's Avatar
cytuss
Wink
Having a similar problem that I need help with. Noticed chirping when I let off the gas at low speeds in second and third. It sounds like its coming from the rear of the truck. I don't hear it so much at high speeds but that could just be because of road noise. Chirps repetitively like a bird. Thanks for any help!
Old Jun 21, 2022 | 09:22 AM
Probably u-joint.
