Code 1757
Old Aug 25, 2022 | 02:10 AM
Handymankiley's Avatar
Handymankiley
Default Code 1757
My 99 Ram 1500 is throwing a P1757 DODGE Code - Governor Pressure Above 3 psi at 0 MPH and not shifting into 1st.. when it is cold is shifts fine but as soon as it warms it is stuck in high gear. I replaced both governor sensor and solenoid and had no change what so ever. Anybody know what solenoid I shoud replace next ?
Old Aug 25, 2022 | 06:34 AM
Moparite's Avatar
Moparite
Did you clear the code?
Also just seen the multiple post.
https://dodgeforum.com/forum/2nd-gen...oad-p1757.html
Old Sep 23, 2022 | 08:11 PM
Handymankiley
yes I cleared the code. It is throwing a P1756 and P1757 now and I do think it is a solenoid problem in the way that it shifts fine when cold. As soon as it gets down the road a ways and warms then it fails.I can shift it into 2nd manually, but not into 1st. Now remember, I replaced both governor sensor and solenoid with no change what so ever.
Old Sep 23, 2022 | 08:53 PM
Then electronics aren't the problem.... Something else is going on.
Old Sep 24, 2022 | 08:31 AM
Moparite's Avatar
Moparite
P1756 Governor Pressure Not Equal to Target @ 15-20 PSI
P1757 Governor Pressure Above 3 PSI In Gear @ 0 MPH
How did you clear the codes? If you have a scanner that can read live data you can see what you are getting from the governor sensor. You can also do a pressure test with a gauge. You should have about 1 psi per 1 mph.
https://www.trucktransdiag.com/downl...nsmissions.pdf
