Relay is very warm to the touch
Old Oct 15, 2022 | 03:11 PM
usmc123456789's Avatar
usmc123456789
Default Relay is very warm to the touch
Title says it, the truck has been turned off for several hours and the circled relay is warm to the touch. I should add that after driving, when I park and turn the ignition off there is a burning electrical smell coming from the fuse box area. It's strange, I can't smell it when driving, just after I park and kill the engine. Any ideas on what's causing this?
Old Oct 15, 2022 | 05:09 PM
That's the time delay relay. So, getting hot isn't a surprise. I don't think it comes into play until AFTER you shut off the engine...... It may be failing, so, probably wouldn't hurt to just replace it.
Old Oct 16, 2022 | 05:56 AM
usmc123456789
Thanks for your help!
Old Oct 16, 2022 | 01:37 PM
Spillage's Avatar
Spillage
My thoughts also… when the contacts get worn down it starts arcing (generating heat)… so it won’t be long before it either quits working, or the relay case starts melting and then it quits working ;-)
