4 wd clicking ? Front right
Old Oct 19, 2022 | 03:47 PM
cj5orion's Avatar
cj5orion
Default 4 wd clicking ? Front right
Good loud clicking,I can hear it in the cab.
Not the u joint or axleOnly in 4 wd.
Searched this forum,wasn't getting anywhere.
I know I need to rip into it to repair,,, I'm hoping I can have needed/suggested parts on hand.No way to get to the parts store after I tear it up !
Brakes,wheel bearing /seals...but the cause of the clicking?
What ya think?
98 Ram 1500
Old Oct 19, 2022 | 07:21 PM
Jack it up, spin things by hand, see if you can find the culprit.
Dry u-joints can make the same noises as loose ones.....
Old Oct 19, 2022 | 09:03 PM
TimoH's Avatar
TimoH
My initial thought, the slide collar may not be fully engaging with the vaccum shift on the axel housing. But, as said above, jack it up, put in 4 wheel drive and rotate the right front. Note: I do not have vaccum forks on any of my trucks, converted to manual engagement. So I dont know if the collar stays engaged with the egine off. Maybe someone can help with that.
Old Oct 19, 2022 | 10:37 PM
Keith_L's Avatar
Keith_L
Eh, it pretty much stays where ever you shove it but without constant vacuum it can/will eventually walk....
Good thought, though.....I also figured similar but my money is more on dry u-joint needles. If it's truly a click I vote needles, if it's a "whir" could be CAD slide collar.
Or if it's not absolutely, positively front axle the front d/s CV centering ball LOVES to click when near death
Old Oct 20, 2022 | 05:55 AM
Moparite's Avatar
Moparite
Turn the wheel to hard left or right then move the truck, If it's the wheel u joints it will click
Old Oct 20, 2022 | 09:48 AM
cj5orion's Avatar
cj5orion
If it was the u joints or axle...
should be doing it in 2 wheel drive also...correct ?
Should have thought about jacking her up and spinning by hand for a up close, personal look see.
Leaning towards the suggestion bout vacuum problem, I've had numerous vacuum issues the last few years.
Old Oct 20, 2022 | 11:00 AM
HeikIlm's Avatar
HeikIlm
Two ways to find the source; do nothing and faulty part will eventually break. Or, lift the front end up and check every single moving part by hand.
Old Oct 20, 2022 | 12:15 PM
cj5orion's Avatar
cj5orion
Ain't that the truth !!!
