I'm Back with a new peoblem
Old Oct 25, 2022 | 10:13 PM
Sirriggs's Avatar
Sirriggs
I have been trying to research for some possible on questioning the gray smoke issue and a lot seem to point towards rings or valve seals? Basically a sigh that the motor be on its way out. I hope I am wrong. The smoke is pretty thick and gets worse if you rev the motor up some. It did sit for over 5 years and was starting to seize up when I started to work on it so that may be the reason for this? Still doesn't explain the gas smell though. The heads were gone through before it sat. They cleaned and inspected so they were good at that time. I can't see them being bad other then maybe seal just gave out, My guess would be more will be known once I do the pressure check this weekend. I will keep you guys updated and go from there. Thanks
Old Oct 25, 2022 | 10:16 PM
Yeah, I think a compression test is definitely in order.... Let us know the results.
Sirriggs's Avatar
Sirriggs
Gray is usually excessive fuel..... If it was running good before, it's likely just a wonky sensor. Have a look at the two-wire coolant temp sensor. (you should only have one. probably near the thermostat housing.) See if it is loose, or damaged. If you have a scanner that can read live data, see what the PCM thinks engine temp is.
I replaced that a few months ago. The only sensor I believe I haven't changed is the map sensor and cam sensor. It was a quart low before the oil change around 2 weeks ago. Also I changed the air sensor in the back of the throttle body and it starts right up and the massive suction has gone away. I noticed the day after it was a little slow to crank up but after I replaced that sensor. It started right up as it did before.
Old Oct 25, 2022 | 10:17 PM
Check it anyway. "New" does not always imply "Good" these days.....
Old Oct 25, 2022 | 10:40 PM
Sirriggs's Avatar
Sirriggs
I still am. I need to know what's going on.
Also I have the Zurich scanner 11 something, can't remember the correct name.
Old Oct 25, 2022 | 10:45 PM
Sirriggs's Avatar
Sirriggs
Also meant to ask you. I replaced the pvc and this new one clicks like crazy. I don't remember that last one doing it. I broke the old one by accident and that was why I had to replace it. lol
Old Oct 25, 2022 | 11:42 PM
AtomicDog's Avatar
AtomicDog
A clicking PCV is normal. That means that the valve is free and not gummed up with old oil/sludge. Hope you installed a MOPAR PCV that the truck calls for as some of the aftermarket PCV valves aren't metered correctly.
Old Oct 26, 2022 | 12:03 AM
Sirriggs's Avatar
Sirriggs
I believe I got it from Advance Auto. Damn thing clicks constantly. At the rate it's clicks. I would believe it will wear out due to it clicking at the speed of light. lol.
Old Oct 26, 2022 | 10:50 AM
I don't really care for the aftermarket PCV valves, they are not always the correct flow rate. The Mopar valve was like 8 bucks last time I bought one....
Old Oct 26, 2022 | 06:03 PM
Sirriggs's Avatar
Sirriggs
Hey, you got me thinking about the excessive fuel. I am starting to thin maybe the injectors I got from 1A Auto. I am starting to think maybe one or more may have went bad since I am smelling a lot of fuel but no leak source can be found visually. My question would how can you tell if spark plug is getting way too much fuel? I could pull the plugs after work tomorrow one at a time and see maybe whats going on. I kept my original injectors so all I would have to do is get new seals for them. I will pull a fuel pressure test before the plugs. Thanks for the help.
