I'm Back with a new peoblem
For the compression test, I am more interested in dry vs. wet numbers. Doing a compression test on a hot motor is not without hazard.
So, pull all the plugs, block the throttle wide open, pull the ASD and Fuel Pump relays, and run the test. Record all the numbers, then repeat the test, but, add a teaspoonful of oil to the cylinder right before you test. See what the numbers do. (record those to, report all findings.
ASD (Auto Shutdown) Relay is right close to the fuel pump relay in the PDC, (power distribution center) It provides power to the coil, and injectors. (probably some other stuff as well...) Pulling them both disables the injectors, and coil, so you don't get any really rude surprises while testing.
Just do the dry/wet test, hot or cold doesn't really matter, its the difference between dry and wet that will tell the tale. (and, the compression numbers themselves) Supposedly, anything over 100PSI is "acceptable" with no more than a 10% difference between the highest, and lowest.
Do you still have catalytic convertors on it? If so, they are probably contaminated by excess fuel which may be why you're having such a hard time clearing them out.
I had a PCM failure hang an injector wide open at 70 mph and actually set the convertor on fire inside. Fortunately the heat caused the head gasket to fail and put out the fire with coolant. That is one smell I will never forget.
A little perspective on 'cat's, brought to you by 26 years of Dodge ownership by Stevie.
I gutted my cat many years ago, cause it broke apart n clogged the exhaust n couldn't afford another one. Down here in the DFW area, 'ol blue, my '96 Ram doesn't even get hooked up to the inspection station computer anymore, which is a good thing. I don't use her to drive any distance anymore, but she does get plenty'o short 'HAUL' trips. At around 250K miles, my short n long term fuel trims are still averaging around 1-3% either side of "0", AFTER the 'cat gut, no matter whether idling or driving. I never seemed to have such numbers materialize before the 'cat was gone. I was told by a trusted mechanic....'you'll regret it (gutting), because it'll mess up your fuel trims, not to mention, set off your money lite!' The inexorable march of time taught me that...neither came about. In fact, I think I musta gotten another 10-20 ponies outta my 5 2, that wasn't there before. Even before the cat broke up. So, if ya don't have the tailpipe sniffing inspectors in your region...
I agree - As long as there isn't a O2 sensor after the cat, the pcm will never know it's gone. My point was only that contamination on an old catalyst can seem to take forever to burn off. Dumping a bunch of excess fuel on a functional cat can result in an internal fire and a whole different set of problems.
I'm pretty sure there is a o2 behind the cat. I'm not sure how much fuel made it in there but the smoking at this point is pretty minimal where it's light on and off like during the winter months. If needed, I can look for a new one and have it installed. I also question if maybe it may have cause some problems with sensor(s)? It took maybe 15 minutes to make it back home so it wasn't very long running with the injector acting up.
Update: Started it today and let it run for about an hour and it didn't smoke but maybe few minutes very lightly then stopped and wasn't smoking so that makes me think it was some residue of what was maybe left in the convertor. Everything looks good so will be doing a good test run this weekend. I'm just glad everything is looking good so far.
