Crank no start
Old Nov 14, 2022 | 02:52 PM
  #21
AtomicDog's Avatar
AtomicDog
Does your check engine light stay on after cranking even after turning the ignition to off, then on again? If not, you may not have a code stored in the PCM yet. Your scanner should read codes stored in the PCM.
Old Nov 14, 2022 | 05:22 PM
  #22
B0dh1M0d3's Avatar
B0dh1M0d3
Not every fault will set a code. That's what keeps troubleshooting interesting.
See if you have spark while cranking.
I do have spark while cranking.. would that rule out crankshaft sensor ?
Old Nov 14, 2022 | 05:46 PM
  #23
B0dh1M0d3's Avatar
B0dh1M0d3
Old Nov 14, 2022 | 07:11 PM
  #24
Yes it would. It's odd that you have spark, but, don't have the fuel pump.... Got a fuel pressure gauge??
Old Nov 14, 2022 | 07:24 PM
  #25
B0dh1M0d3's Avatar
B0dh1M0d3
No fuel pressure guage... Also checking the injectors I'm going from 12 volts with ignition on dropping to near nothing while cranking
Old Nov 14, 2022 | 07:25 PM
  #26
B0dh1M0d3's Avatar
B0dh1M0d3
Could that be because of camshaft sensor
Old Nov 14, 2022 | 07:30 PM
  #27
B0dh1M0d3's Avatar
B0dh1M0d3
  #28
Theoretically, if the coil is still getting power, the injectors should be as well. Since you are getting spark... that means the coil most certainly has power.... The injectors get power from the ASD relay as well...... That is strange. Bad connection for the power feed to the injectors??
Old Nov 14, 2022 | 07:36 PM
  #29
B0dh1M0d3's Avatar
B0dh1M0d3
How can I check that
Old Nov 14, 2022 | 07:44 PM
  #30
AtomicDog's Avatar
AtomicDog
What is the condition of the battery? Is the engine turning fast while cranking or does it slow down?
