Crank no start
Old Nov 18, 2022 | 11:45 AM
  #41
Verify the wires for the relay control circuit are good. PCM controls the relay by grounding that circuit. (engages the relay) If the ASD relay isn't working properly, you won't get fuel pump, or power to coil/injectors.
Old Nov 18, 2022 | 12:29 PM
  #42
B0dh1M0d3's Avatar
B0dh1M0d3
Meaning the wires that that the ASD relay plugs into inside the PDC correct
Old Nov 18, 2022 | 12:47 PM
  #43
You want to test the wire the PCM uses to control the relay. So, pin 86 at the relay socket, to wherever it goes to the PCM.
Old Nov 23, 2022 | 12:56 PM
  #44
B0dh1M0d3's Avatar
B0dh1M0d3
The wire is good going to the pcm from the 86..
Old Nov 23, 2022 | 12:58 PM
  #45
B0dh1M0d3's Avatar
B0dh1M0d3
Would a bad camshaft sensor keep injectors from getting voltage while cranking
Old Nov 23, 2022 | 03:34 PM
  #46
HeikIlm's Avatar
HeikIlm
Does the ASD relay pins 30 and 85 have 12 volts, ignition on?
Old Nov 23, 2022 | 03:51 PM
  #47
If the fuel pump/coil are getting power while cranking, the injectors should as well. They are all powered from the same place.....
Old Nov 24, 2022 | 09:00 AM
  #48
Moparite's Avatar
Moparite
Good as you checked continuity from the pcm connector to the relay? Did you check if the pcm is giving it a ground to turn the relay on?
Old Nov 24, 2022 | 10:36 AM
  #49
I begin to think that is the problem. The PCM is NOT grounding that circuit....
Old Nov 24, 2022 | 11:55 AM
  #50
B0dh1M0d3's Avatar
B0dh1M0d3
Yes good as continuity, have not checked if getting ground from pcm
