PO138 Upstream sensor
Old Jan 24, 2023 | 06:42 PM
Sirriggs's Avatar
Sirriggs
Default PO138 Upstream sensor
Check engine light so checked with tool and PO138 upstream sensor. Went on eBay and it show 3 of them and some just 2. So my question is is it two ( up & down) or 3? 1999 Dodge ram 1500 5.2L 2 wheel drive. My plan is to replace them all this weekend but thought there was only two so this threw me off. Seems like a dumb question but have to ask. Thanks
Old Jan 24, 2023 | 07:07 PM
AtomicDog's Avatar
AtomicDog
Might want to review the information in this thread - https://dodgeforum.com/forum/2nd-gen...ode-po138.html
If you do decide to replace the sensor, please be sure to use an NTK sensor.
Old Jan 24, 2023 | 07:28 PM
Moparite's Avatar
Moparite
And ebay should be the last place you go for parts.
Old Jan 24, 2023 | 09:50 PM
Keith_L's Avatar
Keith_L
This. OP, B1S2 is not an upstream sensor
Old Jan 25, 2023 | 05:54 PM
Sirriggs's Avatar
Sirriggs
I'm going to check out NAPA but where I was confused is showing 3. To my knowledge I thought there was only two up and down. Before and after Cat.
Old Jan 25, 2023 | 06:47 PM
Sirriggs's Avatar
Sirriggs
I just looked up auto parts stores local and NTK aren't available in store pick up and I'm not sure if they can be ordered? How are the Bosh ones?
Old Jan 25, 2023 | 07:20 PM
Bosch suck, and these trucks just don't like 'em. Denso or NTK only please. If that store doesn't have one or the other, call around.
Old Jan 25, 2023 | 07:41 PM
Sirriggs's Avatar
Sirriggs
Ok, Thanks. I will see about Denso.
Old Jan 26, 2023 | 06:50 AM
Moparite's Avatar
Moparite
Mine showed there was a longer rear one depending on the configuration of the truck.Same sensor just with a longer lead.
Old Jan 26, 2023 | 07:33 PM
Sirriggs's Avatar
Sirriggs
Well it looks like I will have to replace up stream this weekend , then down stream next weekend. This will also allow me to check them all and what I would need. I believe this is the first time they have even needed to be changed. lol
