Thank you so much for the info! I ended up not getting the AZ bundle. I usually run the Mopar filter so I’ll check out the videos and go from there. Thanks again!
Originally Posted by Moparite
After some digging found out they are made by Champion Laboratories who makes Champ oil filters. Quality? Since you are looking to run a larger filter might look into the flow and particulate filtration specs of different filters(video above). Just my .
Mopar used the Fram PH8A style since 1958 up till the late 80's when they cheaped out and went with the smaller filters. I was not aware that the V10 filters would fit the magnum. If you have clearance issues you will have to get the 90* adapter. It seems to be discontinued but look around you should be able to find one. I have one of these off a LA motor i bought yeas ago. Neater oil filter changes, The oil runs down and not along the side of the block.
https://www.summitracing.com/parts/D...xWwAN0en9IWVM3
