Truck takes off in drive gear
Old Feb 19, 2023 | 12:32 AM
Mtuck141's Avatar
Mtuck141
Default Truck takes off in drive gear
I have a 99 ram 1500 5.9 magnum with a 2000 46re transmission, when in drive it takes off at a higher gear rather than taking off in first gear, I can manually shift it down to first gear and it takes off just fine but when in drive it takes off slow and is in a higher gear, also when manually shifting from first to second it seems that there is no change in the gears, what should I look into to fix my problem?
Old Feb 19, 2023 | 09:12 AM
Moparite's Avatar
Moparite
In 2000 the sensors (in the trans) changed so they not work with your 99 pcm. Not sure if you can swap the old valve body(and sensors) to the 2000.
Old Feb 19, 2023 | 09:54 AM
Valve body is the same, sensors, and bracket are different.
Old Feb 19, 2023 | 12:17 PM
Mtuck141's Avatar
Mtuck141
We swapped over the wiring harness and sensors from inside the 99 transmission into the 2000 transmission, is there any other sensors it could be?
Old Feb 19, 2023 | 08:36 PM
Did you use the bracket that holds them in from the 99 as well?
Old Feb 19, 2023 | 08:38 PM
Mtuck141's Avatar
Mtuck141
i'm not entirely sure, my dad was the one that swapped everything over while i was gone, i ran a scanner on it today and i have a code for low governer pressure
Old Feb 19, 2023 | 08:40 PM
If he didn't swap the bracket as well, the solenoid likely isn't sealing properly, ask him, see what he says.
Old Feb 19, 2023 | 08:46 PM
Mtuck141's Avatar
Mtuck141
he said he did swap the bracket over too
Old Feb 19, 2023 | 08:49 PM
Gonna need a scanner that can read live data. Governor pressure should be 1 PSI per 1 MPH......
Old Feb 19, 2023 | 08:51 PM
Mtuck141's Avatar
Mtuck141
alright, thanks for the info
