Overdrive Not Working
So basically my overdrive does not work, my truck does not shift into overdrive at highway speeds. The overdrive button is always off, and if I press it, the light is still on. Is this just a bad overdrive solenoid?
Overdrive off button just sends a signal to the PCM, PCM does the rest. Not sure what would happen if the PCM were constantly receiving that signal... might try disconnecting the switch, and see what happens. Theoretically, PCM will disable O/D if trans temp is too high, but, on the 95 and older trucks, trans temp sensor was an option.... Check and see if you have one. It will be a sensor on the trans line, at the front of the trans, just a couple inches away.
P0713 Trans Temp Sensor Voltage Too High
P0743 Torque Converter Clutch Solenoid/Trans Relay Circuits
P0320 No Crank Reference Signal at PCM
Yes! pcm needs that input to stay running. Get a genuine mopar(Mopar # 56027272) replacement not the junk the parts stores sell.
can a code p320 cause engine stalling?
I checked the crankshaft position sensor via the manual, and there seems to be no issue with the crankshaft sensor. So why would it throw a P0320 code?
Trending Topics
If the PCM thinks the trans is hot enough to turn on the light, you aren't going to get O/D.
When was it rebuilt? Any warranty left? Wonder if they used the wrong electronics in the rebuild....
