Transfer case
Old Mar 9, 2023 | 05:01 AM
Darrell Jacobs's Avatar
Darrell Jacobs
Default Transfer case
Hello all hope everyone is well. On to the problem at hand. My question is I have a 1994 2500 v10 4x4. I can get ahold of a 1998 2500 v10 4x4 will the transfer case and rear end and front brakes swap down to my 94
Old Mar 9, 2023 | 08:14 AM
Transfer case won't have the provision for the vehicle speed sensor on the 98, so, you would have to shuffle some parts from one to the other to make that work. (essentially rebuilding the t-case), Rear end will likely work, might have to change the yoke on the pinion though. Not sure on the front brakes. And of course, the gear ratios in the differentials have to match as well. Otherwise, things break.
Old Mar 9, 2023 | 09:34 AM
Keith_L's Avatar
Keith_L
Looking at calipers on RA for a 4wd front, it appears they're the same listings. OP, double check me before spending your money!
Old Mar 10, 2023 | 03:32 PM
dodgetruck2's Avatar
dodgetruck2
I'm not sure on the V10 but make sure you dont have the D44 front axle, some LD V8 2500s got em, especially in 94.
In my experience the provisions are on the transer case output shaft to install a drive gear and C clip, then you just need to use your 94 tail housing to have the sensor mount location
You also have to swap around some hardware and linkage as 98 is when the 4x4 shifter went to be mounted to the floor of the cab instead of the side of the trans, and the transfer will also have a different shift pattern so make sure you steal the **** or the chip out of the **** to swap
Old Mar 10, 2023 | 04:18 PM
V10 won't be a light duty. I don't think that model was available after 95....
Old Mar 11, 2023 | 07:56 AM
Moparite's Avatar
Moparite
The 2500's came in two versions, the 7500 and 8800 GVW. See what you have, I know the rotors are different between the two (thicker i believe) so i would think the calipers would be also.
