Emergency Brake Cable will not tighten
Old Apr 6, 2023 | 07:34 PM
ThatRedRam's Avatar
ThatRedRam
Default Emergency Brake Cable will not tighten
I just replace my rear brakes entirely. I also replaced the emergency brake cables. but i can not get them to tighten up. I tighten the equalizer as fall is it could possibly go and nothing i can still pull the cable in and out by hand. Any suggestion on what may be going on?
Old Apr 6, 2023 | 08:39 PM
Wrong cables, or, the front cable is stretched out too far.... can you get a new one?
Old Apr 6, 2023 | 08:44 PM
Keith_L's Avatar
Keith_L
So even when you mash the pedal you've got slack?
The cables could be stretched. I did this awhile back on one truck I service:
https://dodgeforum.com/forum/2nd-gen...ml#post3538223
Old Apr 6, 2023 | 09:03 PM
ThatRedRam's Avatar
ThatRedRam
also my pedal is sitting in the on position. I just thought that the tension keeps it off. Is the wrong or is my pedal also broken
Old Apr 6, 2023 | 09:04 PM
ThatRedRam's Avatar
ThatRedRam
So theres no tension right now and the pedal springs to the on position. Also the cable is 98inch its a 1995 dodge ram 1500 single cab short bed and its the only size anywhere comes up with so it has to be right. The rear passenger is 98inch and i know the driver rear is correct. Those are the only two i replaced.
Old Apr 6, 2023 | 09:39 PM
Something ain't right there..... tension on the cables should force the pedal into the up position when you pull the release.....
Old Apr 6, 2023 | 09:41 PM
ThatRedRam's Avatar
ThatRedRam
yeah im not understanding it either. But right now with the cable disconnected it is in the up/on position and the release does nothing.
Old Apr 6, 2023 | 09:44 PM
ThatRedRam's Avatar
ThatRedRam
I had my dad pull the cable tight while i pushed the pedal down and it didnt click or lock so pedal also messed up im assuming and i cant figure out why the cable wont tighten
Old Apr 6, 2023 | 09:47 PM
ThatRedRam's Avatar
ThatRedRam
i am missing the springs that go around the emergency brake cable inside the drum. Are they absolutely needed. If they are where can i find them or what are they called?
Old Apr 6, 2023 | 09:54 PM
ThatRedRam's Avatar
ThatRedRam
Just found out its the RETURN springs i am missing so that may explain my issue
