Torque converter problems (maybe)
Old May 2, 2023 | 11:07 AM
KameronG11's Avatar
KameronG11
Default Torque converter problems (maybe)
I have a 97 1500 with the 5.2 and the engine runs great and sounds good, but there's definitely something going on with the transmission. I don't know much about them, but It does not like to accelerate at all, it struggles to get up to 60mph. The torque converter makes a whirring noise after it kicks back down into first gear when coming to stop. And when I'm driving and hit about 45-50mph it drops rpms just a bit and it's like the transmission is doing nothing until I give it more gas, it used to shake really bad when doing the same thing but now it doesn't for some reason. So when it does this I just click overdrive and boom, it starts driving normally. Then I'll turn it off and the rpms drop back, and it's back to acting funny.
Old May 2, 2023 | 02:58 PM
KameronG11's Avatar
KameronG11
Also when I put the truck in gear it won't even move, I can sit there without my foot on the brake and it won't move an inch
Old May 2, 2023 | 03:35 PM
HeikIlm's Avatar
HeikIlm
How is the oil level? Engine idling, transmission in neutral.
Old May 2, 2023 | 03:53 PM
KameronG11's Avatar
KameronG11
Do you mean oil or trans fluid?
Old May 2, 2023 | 04:29 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Transmission oil in neutral. The shaking was probably your frictions and steels going out and the end result. Pull the 8 pin connector on the drivers side of transmission. Manually shift the gears from 1 to 2 to 3 while driving. Does it shift into the gears? If yes, the electronics, get a new kit like this. Rostra are the equivalent to Mopar, and this is a reasonable price. I have no affiliation with OPT. https://www.oregonperformancetransmission.com/product/OPT-A518-A618-EL.htm
If not then it's rebuild time. Unless it's low on fluid and corrects the problem.
Old May 2, 2023 | 05:52 PM
KameronG11's Avatar
KameronG11
So unplug the 8 pin connector and then try to shift it manually?
Old May 2, 2023 | 08:20 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Yup that's the ticket.
Old May 2, 2023 | 11:23 PM
Sirriggs's Avatar
Sirriggs
How would you describe whirring? Just curious.
Old May 3, 2023 | 11:09 AM
KameronG11's Avatar
KameronG11
almost like a tornado siren with a lower pitch, that's the only thing I can I think of lol
Old May 3, 2023 | 11:12 AM
KameronG11's Avatar
KameronG11
I plan on doing this in just a bit, if it does still shift gears after I unplug the connector, what else do you recommend I do other than installing that kit?
