IAT Relocation
Old 05-10-2023 | 01:46 AM
BrendonM's Avatar
BrendonM
Default IAT Relocation
2001 ram 1500 5.2L
Looking to move my IAT to my cold air intake. I have my drill bits and such for the hole but what size should it be and how close would I put it to the cone filter? Just any tips for this job
OEM mopar Replacement
Old 05-10-2023 | 08:32 AM
dodgetruck2's Avatar
dodgetruck2
I believe the threads are 1/4" NPT, can I ask you goal result from this? I would expect the result to be a richer running engine, possibly o2 codes, higher fuel consumption, due to reading a cooler temp then what's entering the engine, so far as placement to the cone I would suggest as close to the intake valves as possible, somewhere around stock location?
Old 05-10-2023 | 06:41 PM
Spillage's Avatar
Spillage
Make sure the cable still reaches before drilling the hole
Old 05-12-2023 | 03:14 AM
BrendonM's Avatar
BrendonM
so it’s not a good thing to do? I’m new and have been looking around. I have to move it eventually when I buy the Air Gap intake so I thought i’d get it out the way now.
my goal for the truck is performance oriented.
however I think it’s already somewhat rich, I installed a 180° thermostat. I can read the live data sometime tmr but I think it’s pulling fuel short term and same for long term fuel trim. I think.
Old 05-12-2023 | 09:09 AM
The stock programming will tend to run the engine a bit rich while in open loop. That's what the O2 sensors are for though, to keep mixture ratio correct, so, pulling a bit of fuel is normal. If the numbers start getting into double digits though.... yeah, might wanna investigate that.
The following users liked this post:
BrendonM (05-12-2023)
Old 05-13-2023 | 06:47 AM
BrendonM's Avatar
BrendonM
IAT 126 @ 65 degrees F outside. At idle
Old 05-13-2023 | 10:13 AM
Sensor 2 always has truly high numbers for fuel trims. Of course, they don't really have very much, if any, influence on fueling. Sensor 2 is just to monitor the cat. That's it.
Old 05-19-2023 | 09:21 AM
dodgetruck2
Are these readings after the relocation or is this your baseline check?
Old 05-19-2023 | 02:02 PM
BrendonM's Avatar
BrendonM
this is with the stock location.
Old 05-19-2023 | 04:33 PM
BrendonM's Avatar
BrendonM
currently a breezy, 73° outside. At idle my reader says my IAT is sitting at 155 degrees.
