Tow haul button fizzled
Old May 31, 2023 | 09:12 AM
2RamsJake's Avatar
2RamsJake
Default Tow haul button fizzled
2001 5.2 4x4 auto trans: tow haul button progressively harder to engage until now seemingly inop. For a while I could get it to work by wiggling shift lever a bit. Any suggestions appreciated, thanks.
Also wondering if I could intercept wires at steering column and install toggle switch?
Old May 31, 2023 | 11:31 AM
The wires for that button are tiny, and fatigue over time, and eventually break. Not sure what all is involved in replacing the button/harness.....
Old May 31, 2023 | 01:16 PM
Keith_L's Avatar
Keith_L
I was wondering, too. Our '98 has had the entire plastic end missing for....well, forever. I was thinking it might be nice to replace the entire shift lever, but based upon experience with Fords I don't want Dorman!!! (if they even offer one - not sure)
Old May 31, 2023 | 01:30 PM
I am not convinced that you CAN replace *just* the button/wires.... I suspect you would actually need to replace the entire lever.....
But, it's just two wires. Pushing the button just sends a signal to the PCM, PCM does the rest. You could put that button anywhere.
Old May 31, 2023 | 09:31 PM
Keith_L's Avatar
Keith_L
RA lists just the button as a Mopar 56021048 but that doesn't include the other "half" the button lives in. Our '98 is missing every ounce of plastic on the end of the steel shift lever
