1996 ram 1500 4x4 5.2
Old Jun 27, 2023 | 09:34 PM
Wvmatt's Avatar
Wvmatt
Default 1996 ram 1500 4x4 5.2
Ok so my ram is running bad it surges at idle then dies always restarts but same story nearly impossible to drive runs rich I can smell gas bad ok so it has new fuel pump and injectors new intake gasket new coil new Iac motor cleaned throttle body and no codes in computer I’m so lost any ideas
Old Jun 28, 2023 | 06:32 AM
Moparite's Avatar
Moparite
What about cap rotor and plugs?
Old Jun 28, 2023 | 11:56 AM
Wvmatt's Avatar
Wvmatt
yes cap rotor plugs wires used correct champion plugs also a new pickup coil sorry I’ve replaced so much I forget everything I’ve done to this also it shows no codes
Old Jun 28, 2023 | 01:47 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Can you get a fuel pressure gage on it to see what the pressure is? One injector is pumping to much gas, even new ones? One injector isn't providing enough gas. Were the fuel injectors new or refurbished/rebuilt? Match flowed injectors if rebuilt? If you are smelling gas I'm surprised the O2 sensors aren't setting a code, unless the computer isn't getting into closed loop.
Old Jun 28, 2023 | 02:38 PM
Wvmatt's Avatar
Wvmatt
It ran this way before all this stuff was changed that’s why they changed all the stuff it started running bad and surging and stalling and they replaced all the stuff listed and it still runs the same so here I come and pick it up cheap and now I don’t know where to look I don’t wanna continue the trend of throwing parts at it I do know that b1s1 is stuck on 1.00 volts and don’t switch much at all and I think it is stuck in open loop may have to check again to see if ol or cl but I am gonna change the o2 this weekend but I don’t feel this will fix my issue
also has a new alternator and battery I’m feeling a computer issue I just was hoping someone else may have had this same issue
Old Jun 28, 2023 | 03:42 PM
Does it run bad right away? Or will it idle smooth for a couple minutes when cold, then start running crappy?
Old Jun 28, 2023 | 06:23 PM
Wvmatt's Avatar
Wvmatt
It’s not great when cold but it does get worse as it warms
Old Jun 28, 2023 | 08:32 PM
How old are your O2 sensors??
Old Jun 28, 2023 | 09:10 PM
Wvmatt's Avatar
Wvmatt
Have no clue I have a new upstream imma change it this weekend downstream seems to work good when I’m watching the data
Old Jun 28, 2023 | 09:16 PM
What brand? NTK or Denso only please. These trucks don't like Bosch sensors.
