Speedo signals
Old Jul 8, 2023 | 01:02 AM
JackJack135's Avatar
JackJack135
Default Speedo signals
I have a 1995 Cummins motor and 1995 47re. (Yes it’s a 95 re it was one of the first off the assembly line.) Behind it is an np241 passenger drop out of a 90s dodge gasser. And the rear axle is a Dana 70. I have a speedometer I want to hook up but I’m having trouble figuring it out. The 47re has a 2 prong vss that’s plugged into my pcm. Tcase has a 3 prong vss that’s unplugged as of now. And rear end has a 2 prong sensor that’s unplugged but I believe it’s used for abs. My Speedo can take a square wave signal, magnetic pickup with 2 wires, or a Hall effect sensor. Just trying to find some guidance on making my Speedo work. Anything is appreciated.
Old Jul 8, 2023 | 01:10 AM
AtomicDog's Avatar
AtomicDog
Can you possibly provide some additional details regarding the speedo that you plan to use? A photo and it's input would also be helpful.
Old Jul 8, 2023 | 01:43 AM
JackJack135
speedo
i think that link will work. It’s a speedway electric speedometer. I can send a pic of the diagram in the morning with some pics of the senders too if you’d like. I don’t care what sender I use. Which ever is easiest I guess. The wiring harness I have has a plug that’s supposed to go in the tcase but the different model 241 doesn’t have the same plug. But basically I know the Speedo says it can have 2 wires from a magnetic pickup. 1 wire for a square wave signal, or your standard Hall effect setup. I think the 47re sends a square wave signal but I’m not entirely sure on that.
Old Jul 8, 2023 | 06:19 AM
Moparite's Avatar
Moparite
According to the link it "may" not fit. What is wrong with the stock speedometer?
Old Jul 8, 2023 | 09:08 AM
Speedo on the older trucks gets its cue from the VSS in the tailhousing of the trans (2wd) or T-case (4wd.) Should be able to just plug it in, and it should work.
Old Jul 8, 2023 | 09:20 AM
JackJack135
I guess what I’m looking for is some information on the sensors themselves. This is a drivetrain swap, it is sitting in a 1978 Chevy k30 and I redid the whole dash that’s why I’m using this gauge. I figure one of the three vss on the drivetrain would do the trick. But like the vss in the tcase has 3 prongs and I’m assuming one is a sensor ground, one a signal, and one like a 5v supply but I don’t really know, and I don’t know what signal it sends. I don’t know what type of signal any of the vss send.
Old Jul 8, 2023 | 10:08 AM
Tone ring and hall effect, so, square wave?
Yep, one wire is 5 volt feed, one wire is signal return to the PCM, third wire is ground.
Old Jul 8, 2023 | 10:04 PM
Nicholesoall's Avatar
Nicholesoall
New Member
Default To me
Just want to say your article is as amazing. The clearness in your post is simply excellent and i could assume you are an expert on this subject. Fine with your permission let me to grab your feed to keep updated with forthcoming post. Thanks a million and please keep up the enjoyable work.
Old Jul 9, 2023 | 10:29 AM
Moparite's Avatar
Moparite
The gauge you linked is a stand alone unit so it may be different from what the factory used.
This speedometer will work with either a 16 or an 8 ppm sender.
Found some info you may want to look over. They do offer a GPS sender for that gauge.
Old Jul 9, 2023 | 07:14 PM
JackJack135
i didn’t end up feeling like running a 5v supply to the tcase so I spliced into the output shaft speed sensor in the 47re tailhousing. Each end of the magnetic sender to the gauge and it works. It seems a wee bit off and I can’t find anything online to what ppm the sender makes so unless any of y’all know, the gauge has a manual calibration I can run a fixed mile track and get it dialed in. But it does work, you can run a Speedo off the output shaft speed sensor in a 4wd 47re. I answered one question at least.
