Engine bay cleanup
Old Jul 12, 2023 | 07:19 PM
mcgraw's Avatar
mcgraw
Default Engine bay cleanup
What’s the best way to clean the grease off the engine?
I don’t think my alternator ground wire is routed correctly. Can someone tell me where it should be going?
Old Jul 12, 2023 | 08:33 PM
Keep in mind, Dodge in their infinite wisdom... use a black wire for the power feed back to the PDC.....
Old Jul 13, 2023 | 07:08 AM
mcgraw's Avatar
mcgraw
Haha. Yeah that’s no ground… which I should have known since I had to fix some skinned up portions. Anyway, something is wonky with it. It’s in the way when I put the air cleaner on.
Old Jul 13, 2023 | 09:42 AM
AtomicDog's Avatar
AtomicDog
I typically get the engine warm and shut if off. I spray it liberally with Gunk engine degreaser (or equivalent) and let it sit and work for awhile. Lastly, I'll restart the engine and wash the engine down with a water hose, being careful no to get too much water on the distributor. If the grease is heavy and thick, I may have to repeat the process.
Old Jul 13, 2023 | 12:42 PM
aleekat's Avatar
aleekat
Pretty good
