2002 Dodge 2500 5.9V8 4WD Differential
How can I find out just what type of rear and front differentials that are on my truck? The truck has a Posi traction differential on the rear and the front is just standard front. I need to replace the fluids and am having difficulty finding the correct gaskets for the covers.
I would suspect you have Dana 60 front and rear differentials. You might be able to put your VIN in here and get the build sheet for your truck:
https://fcagroup.my.site.com/RAM/s/equipment-listing
Thanks to all who replied! Yes I do have Dana 60 front and rear gears. I know the rear has Posi as that's how I ordered it. What is the best gear lube to use? Truck has 129k on it but never replaced the fluids. Don't want to spend a ton of $ on lube as truck is used sparingly now.
If it's just normal driving, 80W90, plus the LSD additive, if you do towing/hauling, 75W140 synthetic, and the additive. I generally just use whatever the parts store has on the shelf. (castrol, mostly.)
Trending Topics
I changed the rear lube and used Castrol, I think. I got the 75-90 full synthetic. As for the gasket, I just used RTV. The Castrol had limited slip additive and came in a plastic bag. A lot handier than trying to get underneath and fill the unit with a bottle. Much faster and you get all of it in there.
